Trane Mini Split code E1
ShelleyH1975
Member Posts: 1
The unit just stopped blowing both units inside display E1 only one unit was running at the time is there a fix for this
E1 is a generic communication error. It's probably a sensor somewhere. You could try shutting off the breaker for 5 minutes. It's not a light bulb, so give it the 5 minutes. Then turn it on and see.
Is it you're only heat source?
How old is it?
The outdoor unit isn't obstructed?
- 123 Chimneys & Flues
