Aquastat buzzing and shutting off
Colin11
Colin11 Member Posts: 1
Hi, I have a peerless gas boiler and my aquastat is buzzing and shutting off the boiler. I've got to replace it but apparently it's been discontinued..its a Honeywell l8148e1182. I'm not sure what I could use to replace it. Any information would help. Thanks
    109A_5 Member Posts: 3,889
    Hello Colin11,
    Probably bad solder joint connections at the internal relay, but your system may have other issues. I believe there are less expensive aquastats by other manufactures.
    https://www.supplyhouse.com/Resideo-L8148E1265-High-Limit-Vertical-Mount-Aquastat-Relay-15-DegreeF-differential
