Weil Mcclain XVT-24
WilliamG89
Member Posts: 2
in Oil Heating
I just had a friend come by drained water, it had an loc code, once I turned the boiler back on, the panel was buzzing, and the code 131 kept increasing. Need to fix this, anything can help
Is this a steam system? If so, did you mean "VXT-24"?
Consulting0 -
Hello, yes that is what I meant, it had a code and I had someone come by it is on, flushed water out of it. So hoping it doesn’t stop again and get the LOC code
LOC means it kept feeding and locked out because the call for water went on too long. This may be a problem with the VXT or with the low-water cutoff. Where are you located? We might know someone who can help………..
Consulting0
