Bit different
That's probably the oldest Clow GasSteam radiator I've seen. For those not familiar, this unit has a pool of water in the base and a gas burner to boil it. Most of these are unvented, which would make them illegal to use in many jurisdictions.
Consulting5 -
i travel through western Maryland a few times a year .
Your welcome to one
Don't pitch them. Some folks collect those.
Pretty cool!
I know they aren’t in use and frankly, was kinda dangerous hence their fall from grace, but cool concept at the time. I would totally have one on display as decor or make them into end tables for a backyard patio/man cave.
Lifelong Michigander
-Willie
The funny thing i used to see them all the time about 25 to 30 years ago in paterson nj in a scrap yard where i would occasionally get salvaged radiators never thought much about it . Since then i don't think i ve seen even one in any scrap yard guess they all are ancient maya history now . Thanks for sharing your find .
Ps Ed your looks sweet
peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating1 -
These things are amazing.
Dave in Quad Cities, America
http://grandviewdavenport.com1
- 117 Geothermal
