Megasteam combustion test location
Robert_H
Robert_H Member Posts: 294
Reading the megasteam 396 I&O manual, it is clear that the breech draft should be measured in the canopy (pressure tapping at the rear of the boiler) but its not clear if combustion gasses and stack temp should be measured in the canopy port or in the smoke pipe as is in most other cases. the gasses might not mater but I think the Temperature in the canopy would be somewhat higher than in the pipe. so those of you with more experience, how do you do it?
