Spare parts for a TT Instinct Solo 110
FB
FB Member Posts: 47
edited January 2025 in Gas Heating
A local Contractor replaced our Buderus mod con with a new Triangle Tube Instinct Solo 110. It has been working well for over a year. We need it for cental heating and DHW, so I'd like to have a stock of failure prone parts on hand. As the igniter is only warranted for a year, I'm guessing that's a high failure component. Based on your experience with this boiler, what do you suggest? Thanks in advance for your thoughts.
  • psb75
    psb75 Member Posts: 1,128
    Triangle Tube is a longstanding co. Parts are generally available.
    The igniter is considered a "consumable" part. It gets replaced more than any other part so having one or two on hand would be good. I have replaced things like PCB boards but that is a big $$ part to have on hand. Fans can go bad. Various sensors. Some gaskets for replacing igniters.
