Rinnai controller readings, flow??
dpenny
dpenny Member Posts: 24
What are the units on controller read out for flow rate? I cannot find in any Rinnai manuals, and I have 6 of them.
The quantities are in 20-44 range depending on when filter was cleaned.
I cannot get close enough to circ pump to read it's labels.
  • psb75
    psb75 Member Posts: 1,126
    What kind of 6 Rinnai's are you talking about? Rinnai makes a lot of models.
  • hilltown
    hilltown Member Posts: 76
    Back side of the cover, small paper in the vinyl pouch, it will tell you how to read flow rates, usually 01 is flow rate and you need to a add a decimal point , so 18= 1.8. And 7=.7 gpm
  • dpenny
    THX. You'd think some of their MANY manuals would tell this fact.
