What kind of steam trap cage is this ?
Jchenabc
Jchenabc Member Posts: 15
Trying to see the condition of my steam trap. I have the warren webster 712 HB trap, when I opened it up, it seems like someone rebuilt it at one point with something other than B&J or tunstall cage. I am not even sure how to get it off from the cap. Appreciate any tip on this.
    Steamhead Member Posts: 17,885
    No, that's original Webster. Those numbers mean October 14, 1927.
    Consulting
    Mad Dog_2TKPKIntplm.
  • Jchenabc
    Oh wow. Looks pretty good for almost 100 years. Wasn't sure how forceful I need to remove the element.
    Mad Dog_2
  • guzzinerd
    guzzinerd Member Posts: 335
    I replaced 30 from the same era, you can keep the housings and get new innards with a taller cap.
    Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
  • Jchenabc
    @guzzinerd B&J site is saying use 1764 cage unit with existing cover. Where would i go about finding a new cap that will work it ?
    guzzinerd
    Consulting
    guzzinerd
  • guzzinerd
    Lucky. Mine were a different brand, needing new caps
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,260
    Tunstall has or makes everything Steam Trap. Mad Dog
    Intplm.
  • Jchenabc
    I finally got it off ! It is basically 2 layers of metal bellows. It came off with some brute force with the help with dremel. I guess  warren webster never had the intention of having it replaced, since there is no screw or anything. Will try to post some picture on the next one.
    mattmia2 Member Posts: 13,374
    Or it has corroded itself in place over the past 100 years.
  • Jchenabc
    You are right ! 50% chance of it actually unscrew nicely.
  • tim smith
    tim smith Member Posts: 2,870
    edited January 31
    Tunstall replacement # is TFWW2515, using same cap (verify with Tunstall on the # & procedure, great people) also I think we had to pull seat . Did about 100 of them little over a year ago. Just tear out the old element if wont unscrew from cap. Dont need the treads in cap for the tunstall
  • Jchenabc
    I picked up some old/new barnes and jones 1764 from ebay for cheap. but seems like TFWW2515 is a little cheaper new from Supply house, will probally go with Tunstall for the rest.
