1953 baseboard identification ?
joel_19
joel_19 Member Posts: 933
Anybody know what this is ? How bout a heat output chart ? The house dates from 53 it’s set up mono flow style . Fins are 2.3/4 X 3.3/4 approximately 46 fins per foot
    EBEBRATT-Ed Member Posts: 20,145
    I don't know the mfg but all baseboard is pretty much the same around 550 btu/foot at 170 avg water temp 180 in 160 out.
    EdTheHeaterMan Member Posts: 12,127
    Your baseboard looks short. I would use the 550/ft @170° number. You can find some baseboards that are as tall as 9" that may have a 650/ft @170°, but most of the 7" and shorter baseboards will be in the 500 to 550 range.
  • joel_19
    yes 550 was what I was thinking. I was hoping to come up with a brand and an actual chart to get as precise as possible because the Client wants to go ATWHP.
