Hello, can anyone help me identify what brand furnace is this? Trying to get some info on it
I was call to service this furnace, it seems very very old. This is the only name plate on it. I would like to get some information on it before attempting to do any work on it. Thanks very much for your help as usual.
This was probably a small local or regional manufacturer. Marietta is a small town in Lancaster County, PA along the Susquehanna River just north of Columbia. If there is a historical society there you might check with them.
Consulting0 -
Apparently no luck a decade ago.
https://forum.heatinghelp.com/discussion/81740/marietta-metal-products-co
One Pipe System0 -
Should be about the same as any other boiler from the 50's/60's. Probably 60's since it seems to have a combination valve.
Couldn't find much info on this gas fired steel boiler either, but here is its water rating from the Beacon Boiler Reference Book for new boilers between 1959-1972. https://heatinghelp.com/assets/documents/201.pdf
Forum Moderator
