Hello, can anyone help me identify what brand furnace is this? Trying to get some info on it
  • efarrenovate
    efarrenovate Member Posts: 6
    I was call to service this furnace, it seems very very old. This is the only name plate on it. I would like to get some information on it before attempting to do any work on it. Thanks very much for your help as usual.
    Steamhead Member Posts: 18,491
    This was probably a small local or regional manufacturer. Marietta is a small town in Lancaster County, PA along the Susquehanna River just north of Columbia. If there is a historical society there you might check with them.
    Consulting
  • bburd
    bburd Member Posts: 1,303
    Given the age of that boiler it is probably very simple, with industry standard parts like gas valve or oil burner, circulator etc. Servicing should be quite straightforward.
    Bburd
    mattmia2SuperTech
    109A_5 Member Posts: 3,978
    mattmia2 Member Posts: 16,739
    edited January 2025
    Should be about the same as any other boiler from the 50's/60's. Probably 60's since it seems to have a combination valve.
    EBEBRATT-Ed Member Posts: 20,164
    Looks like a boiler not a furnace. I can see a circ pump.
  • HeatingHelp.com
    HeatingHelp.com Member, Moderator, Administrator Posts: 228
    Couldn't find much info on this gas fired steel boiler either, but here is its water rating from the Beacon Boiler Reference Book for new boilers between 1959-1972. https://heatinghelp.com/assets/documents/201.pdf
    Forum Moderator
