Dunkirk boiler ignition control module
HeatingHelp
HeatingHelp Administrator Posts: 722
edited January 2025 in THE MAIN WALL
This discussion was created from comments split from:
Intermittent pilot ignition control - replacing cable/wires?
  • sama1122
    sama1122 Member Posts: 1
    hi folks, I see this old thread but relevant to my case a bit. I will be replacing the 1003-611A module and was thinking about changing the ground spade connectors as the old ones are pretty corroded. i however cant figure out the size that i need. Really appreciate if someone can help me with what size of spade connectors i can use. and what material would conduct best. the existing ground wires dont have any gauge (AWG) info on them. Thanks much in advance.
  • HeatingHelp.com
    HeatingHelp.com Member, Moderator, Administrator Posts: 227
    @sama1122, welcome to Heating Help! I've created a new discussion for you here to prevent confusion and to prevent your post from getting lost at the bottom of an older discussion.
    Forum Moderator
