Gaskets for this manifold
RayWohlfarth
RayWohlfarth Member Posts: 1,979
These manifolds are leaking and we would like to know if the gaskets are still available. These were the the old Wirsbo manifolds. thanks all
Ray Wohlfarth
Boiler Lessons
  • GroundUp
    GroundUp Member Posts: 2,513
    I found some a couple years back, I think on supplyhouse for a couple bucks. I also got a pair from my local Uponor distributor, and I once made one from a football style flange gasket in a pinch.
  • Intplm.
    Intplm. Member Posts: 3,005
    Its been a while but I think you might be able to us a gasket/washer that is similar to a water meter washer of the same size. Im not one hundred percent on that. Of course you would need to look and see if the washer in compatible with the heat range.
    hot_rod Member Posts: 27,416
    edited January 2025
    It’s just a fiber washer. Buy some 1/8 gasket material at an auto parts store and cut out some new ones
    It is a 1 or 1-1/4” g thread if you want to buy a couple options.
    a R20011 Caleffi number, a 1" G thread washer 30 mm OD, about 1.18"
    R0001454 is a 1-1/4 G washer 36 mm, 1.40"
  • RayWohlfarth
    Thank you @GroundUp @Intplm. and @hot_rod
    I appreciate it gentlemen
    Ray Wohlfarth
    Boiler Lessons
