Munchkin Humming Noise
We had pump replaced on Munchkin boiler and now whenever it fires up sounds like a cruise ship. Noise can be heard outside and 2 floors up. Boiler works fine but Noise throughout the day is unbearable
Is the new pump the same size as the old one? Is there a ball valve where you can adjust the flow to see if the sound changes or some way to turn off the pump for just a few seconds to see if it’s a flow issue? If not a flow issue, it could be combustion needing a combustion analyzer.
The unit has 3 Grundfos pumps that have settings C1 low, C2 med & C3 Max. Just discovered that all 3 pumps were set at C3 max for a 2 story house. Not sure if contractor changed all the settings but was not making noise before he did work.
All the same size, sorry didn't answer question. The one near gauge (closest to floor) ⁷was replaced.
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
