Help Identifying A Radiator Part
Hello,
Can you please help me understand what this is and if/how it should be adjusted? When my boiler is running, I can hear steam coming out of it and I see a few drops of water on the pipe below. Is that normal?
Thanks
It is an air bleeder for a hot water system. Put a screwdriver in the slot and turn it clockwise. If it doesn't stop leaking you will have to replace the vent and drain the boiler to do it.
It's a Hoffman No 500 air vent
It came in a package that said for water or steam, didn't work great for either, but worked a little better for water
Those “coin” style air vents for steam cast iron baseboard eventually fail when the hydroscopic material that seals them fails. What you want to do is add a brass nipple to a brass elbow/coupling to install a small typical radiator vent.
See this thread:
https://forum.heatinghelp.com/discussion/153455/baseboard-vent-one-pipe-steam-system
1
- 50 Industry Classes
