Bosch Greenstar temp drop
Here’s my scenario
I have a Bosch Greenstar 151 combi boiler. We usually burn wood for heat, but once the stove goes out the boiler kicks on. Last night I woke up at 3am to shower. When I got done I walked into the laundry room and noticed the temp on the boiler was reading 68 degrees Fahrenheit. I thought this was low, as it normally stays above 100. The pressure was reading normal. Nothing was running at the time. I turned the thermostat up and the heat kicked on like it should and the boiler heated to around 155 like it normally does. Once the heat shut off I ran the hot water and the temp dropped on the boiler but it cut on once it reached around 117, like it normally does.
My question is, why did it drop to 68 and not kick on? This is the second time I’ve noticed this happen this year. The pressure was fine
Side note: it was pretty cold last night and I don’t think the heat had cut on yet since the wood stove was running
either there’s not a problem or maybe reword the description a little—-what was the thermostat set at? The house was colder that it was supposed to be? Just because the boiler says 68- that doesn’t indicate a problem. It means the boiler isn’t doing anything at that time
Could be a thermostat issue. Do you have multiple zones or just one? If multiple- you likely have a zone controller that indicates when you have a call for heatDo you have the FW200 control on the greenstar? There’s some factors that make it hard to offer lots of input
The boiler only does what it needs to do to satisfy the thermostatic demands for heat (1.) central heating and 2.) domestic hot water). Hence its high efficiency. Enjoy it.
- 50 Industry Classes
