Flame
I have a bradford white brute FT combi wall boiler. DHW FLAME WORKS , HEATING FLAME DOESN'T COME ON WHEN CALL FOR HEAT. I'm pretty handy and fimilar with pull and plug. I've called 20 plumbers non are familiar with this boiler. I've called Bradford they told me replace control board/ display board. Still doesn't work. There's one burner FLAME for both sides it can't be gas issue or ignition because it comes on for DHW. just doesn't come on when it calls for heat. Now I hear the fan and motor come on but not FLAME. TO be honest no one is helpful on this so I have to figure it out myself. It's probably a sensor or something stupid. Anyone have a clue.
What code is it giving after it locks out? What's the model number of the unit?
@tommy123 Has the system ever operated correctly? How long have you owned this boiler? When did the problem first start? Do you have the BMFTCW-199 or the BMFTCW-140, or a different combi boiler?
you need to post model number for help. pics will help
