Steam Trap
Been doing this work 35 years and have not seen this type of steam trap. Can any of you tell me what it is called and should it be mounted in the position shown? The radiator hammers and I am suspecting this trap is mounted in the wrong position.
It almost looks like a Broomell Elbow?
I would say that should be mounted vertically with Plug on bottom. Mad Dog
2 -
@Steamhead probably knows. I would raise the rad on blocks and repipe
Almost certainly some sort of vapor system and not really a trap, probably a check ball sort of device. what kind of valve is on the radiators?
mine work well and I haven’t cleaned them in 34 years
Cant hurt to raise up in wood blocks, as suggested, install it vertically & see how it goes. Mad Dog
Just a question, will the eccentric fitting cause problems, the book shows it on the center line.
It's an O-E return elbow, as illustrated in the upper left of the "Vapor Devices" scan. Also appears in chapter 15 of @DanHolohan's "The Lost Art of Steam Heating". And yes, it should be vertical.
Consulting1 -
Not with that one. The other one is a Richardson, and it needs to be on center.
Consulting0 -
grosse paointe michigan?
yes, the park. I borrowed 2 of Dan’s books from our library and have a 3rd coming from another library … feel like I need to buy 1-2 for all that I have learned.
If he is independently wealthy I won’t worry about it … if he has a go fund me or a favorite charity, sign me up.
- 116 Geothermal
- 15.8K Strictly Steam
- 52 Industry Classes
