Book
Can anyone recommend some books written by Dan Holohan that are only about hot water boilers with illustrations and introduce the functions and uses of each accessory! It would be best if it was written by him, but if it is not written by him, you can also recommend it if it is a good book
thanks all of you guys
There is one more that I would recommend that Dan Wrote but it was uncredited.
It is right to the point with illustrations and is not a long read.
It's called Zoning Made Easy offered by ITT Bell & Gosset.
It's worth a look.
I think I already sent it to you Jin:
https://s3.amazonaws.com/s3.supplyhouse.com/product_files/108119-Reference%20Guide.pdf
This is a rewrite that removes some of the products that Bell & Gossett no longer market.
2 -
Ray Wohlfarth wrote some good books, too.
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 962 Plumbing
- 385 Solar
- 15.3K Strictly Steam
