Searching for discontinued gas valve
jbkeohan
Member Posts: 2
I have a Weil-McLain HE II boiler using propane. Serial Number CP2590737
I need a new gas valve Model 36C74. Part has been discontinued and no replacement part is available. I have checked area supply houses with no luck. Any suggestions? Does anyone have a valve kicking around? Thanks!
Thanks ScottSecor! I will check this out and hope for the best!
- 50 Industry Classes
