Is this sound a leak? When can I refill
leaking
leaking Member Posts: 153
edited November 2024 in THE MAIN WALL
Weil Mc lain 6/23 after running for 20 minutes when cooling it sounded like water dripping on hot metal. It got slower as it cooled. I don’t remember the sound last year but I’m not sure . I recorded the sound but could not figure a way to include it here .
2nd question. I am flushing it tomorrow, how cool does it have to be for refill. About how long does it take to cool enough? Room is 70, water temp 70. How do I measure temp to know it’s cool enough? I have an IR thermometer, and fans to help cool. Suggestions on refilling would be appreciated. .
The drip noise and sizzle sounds like a drip is hitting the burners when shut off about once a second and reducing in frequency as it cools, maybe it just contractions ? What do you think it is ? Could I slide a piece of cardboard over the burner after it’s shut off to see if it gets wet? I don’t know not being there if there is any room to slide it in.
    EdTheHeaterMan Member Posts: 12,127
    I have posted a video on facebook then posted the facebook link to click on. But that was 20 years ago. there are several ways to link videos here. YouTube is a popular one.
    As far as a Weil McLain 6/23… is that the date it was installed? Is that a model number of an old coal fires conversion from the 1930s?
    Do you know if your boiler is a steam boiler or a hot water boiler?
    Do you know the model number of the boiler?
    can you post a photo of the boiler from far enough back to see the pipes from the floor to the ceiling that are connected to the boiler?
  • leaking
    it’s a Weil Mc lain LGB 6/23 steam in 12 unit installed about 11 years ago . It’s run to about 1lb, blow down until clear about twice a week. Flushed yearly . Maybe 600,000 btu
    HVACNUT Member Posts: 7,424
    Flood the boiler.
    Mad Dog_2
  • leaking
    what do you mean “flood boiler” fill it way up to see if water drips when cool?
  • leaking
    pipes are all insulated with thick fiberglass .
