Vent Damper Motor Stuck?
Hi everyone!
I’ve been having an issue with the automatic Vent Damper Motor on my WM boiler. Seems to stick and a quick smack allows the motor to turn again. HVAC tech simply disengaged the motor in the open position for now.
I know this solution is temporary and I’m sure not very efficient.
Before investing in a new motor, curious if there is anything that can be done to bring the motor back to life.
Thank you!
Nope. Just replace the motor.
Consulting1 -
Before you spend over 200 on a WM part look at the Field Controls part number. This one may be a better value. https://www.supplyhouse.com/Utica-Dunkirk-240005933-Vent-Damper-Motor. That is a plastic mount model, If you want the metal mount model like the Orig Equip Manuf. then look at https://www.supplyhouse.com/Field-Controls-70009800-GVD-Vent-Damper-Motor-Assembly-Metal-Base?_br_psugg_q=gvd+motor
@HVACNUT That is an old part number, the current part number is 381-800-477 and that is way more $$$$ than the motor only I listed above. WM parts markup is outrageous!!!!
2 -
Thank you @EdTheHeaterMan !
Aside from the housing, is there any benefit to metal versus plastic? Or vice versa?
Same motor, etc?
Thanks!
I'm not sure, That would be a question for Field Tech Support. I would pick the metal one to be sure. They are identical and I know that they fit. It looks like the same motor and control system inside however there may be a slight dimensional difference on the mounting holes.
Mounting dimensions are the same. I've used both.
Consulting1
- 120 Geothermal
