I built a condensate pump that doesn't need power?
b4racing
b4racing Member Posts: 3
ok ok.. its not a pump. After recently installing a condensing boiler into my shop that is above grade, and has no plumbing, I needed to solve my condensate issue. Being up North with freezing temps most of the year, I was told I had 2 options:
1: Drain out the building and heat trace the pipe.
2: Condensate pump out the building. This works because the pump runs periodically and with enough flow not to freeze. The killer for freezing is the trickle.
Since its a hobby shop and I'm not out there everyday I didn't like either option. Too big of a chance for failure. Or maybe I'm just stubborn and had to make things hard. Anyways, I set out and built a tank for my condensate that automatically drains once full. This creates the periodic and larger flow similar to what a condensate pump provides but without power. Picture roughly a 16" tall 4.5" diameter tank. Condensate drips in after the neutralizer and flows out periodically with enough flow not to freeze.
Now the reason for my post. Is there a market for anything like this? On one hand I am thinking possibly, might just be because I think its cool. On the other hand, most boiler installations are going to be in places that have interior plumbing for drainage, or below ground which would require a pump to get above grade. Thoughts??
Mad Dog_2
  • RickDelta
    RickDelta Member Posts: 621
    edited November 2024
    @b4racing
    Yes! …. its called a "siphonic dosing pump" (No power or pump!)
    ….. it waits until your tank is full, only then, drains the entire tank all at once at full force (contains no moving parts or valves!)
    https://www.siphons.com/
    delcrossv
    HVACNUT Member Posts: 6,734
    Is this like a secondary trap that once condensate is up to drainage level will only put out what comes in, or is there a float switch or another mechanism that will empty the whole cylinder?
    Regardless, the piping to outside needs to be thought out. Discharge tubes can still freeze when using a pump. You don't want water back trailing and damming itself closed. Start the down pitch inside. Protect it from wind.
  • b4racing
    Yup, somewhat. The very small flow from the boilers made it much harder though.
    Yup. Its a 16"tall x 4.5"diameter tank after the neutralizer. No float switch, it works on a siphon system like Rick mentioned, but took some significant experimentation to make work for the very low flow of a boiler
  • RickDelta
    @b4racing
    …… look up "urinal siphonic trap"
    Its got a special low flow tank fill trip set-up.
  • b4racing
    I've built a tank that works great! The intent of my post is asking if anyone see's a market for this type of product to be sold and marketed specifically for this. I am considering building and selling them.
    Maybe Ill word it this way, what percentage of boiler installs would this benefit or be used on?
    hot_rod Member Posts: 24,973
    it seems 90% of the time a floor drain or condensate pump covers it. I think it would be a pretty small niche product.
    Getting it to market could be a challenge . Maybe approach Rectorseal or other companies that specialize in solutions for condensate removal with the idea
  • RickDelta
    @b4racing
    ….. pssssst! psssssst! b4, I've got one word for you ……. "plastics" !!
    https://www.youtube.com/watch?v=PSxihhBzCjk
    (from the movie "The Graduate" ) : )
    To make your fortune, design and build "Carbon/TAC" media water descaling filters for the commercial Hotel/Motel and Laundromat industry.
    The highest demand is for the scale prevention in the tankless hot water systems.
    You can fabricate even the largest commercial sized capacity units …… easily right in your garage.
    Good luck! : )
  • GroundUp
    GroundUp Member Posts: 2,343
    In my 18 years in this trade, I have only found a use for something like this maybe 5 times. All of which were covered by a 120v condensate pump. This certainly isn't a new technology, but a combustion condensate specific (maybe with an internal neutralizer?) type unit may have a merit for off-grid properties or those who like to way overcomplicate things and reinvent the wheel. It'd certainly be worth approaching somebody like Axiom to discuss marketing, but I wouldn't expect to be getting rich on this venture.
    mattmia2 Member Posts: 12,546
    I'd probably just make it out of pvc pipe and fittings if i needed something like that.
    "Scale prevention" is tricky because what prevents scale also pretty easily leaches lead from the plumbing system if there is any excess and if there isn't excess then it is likely to deposit scale.
    RickDelta
