Calling heat on 1 zone also heats other zones
2»
  • thomagr
    thomagr Member Posts: 28
    I reached out to Taco support mentioning my pump were 007-F5 probably from 2008 and they responded:
  • SteveSan
    SteveSan Member Posts: 298
    I did some digging into our archives and the 007 was the first pump we redesigned to insert an IFC around 2006-2008.
    2016 was when Taco finished redesigning the rest of the 00 series to accept an IFC on the standard non IFC pumps.
    bburdthomagr
  • thomagr
    So I’ve checked all 6 pumps date code and I have:
    • 5 pumps with “8 09” (those are green)
    • 1 pump with “5 07” (this one is black)
    I guess 09 ones will accept the IFC, 07 might be a gamble. I’ve ordered the part, I will keep you posted :)
    Thank you all again!
