Air Gap on Condensate Drain
Is it necessary to have an air gap on a condensate drain? The Weil-Mclain EcoTec boiler has a condensate trap to prevent combustion gasses escaping into the house and this is followed by an acid neutralizer. Then it goes to a 30 ft long, 1" PVC drain which dumps into the sump. This 1" PVC is shared with my water softener which does have an air gap. Should there be an air gap between the neutralizer and the 1" PVC? It cannot share the air gap with the softener because it is too far away.
I always put an air gap on the condensate as the drain comes out of the boiler. If you don't put one in and it gets clogged, water will back up into the heat exchanger and cause all sorts of trouble.
Two btu per sq ft for degree difference for a slab1 -
Yes , if not you can throw a error code …
OK. I thought so, but I didn't want to make things more elaborate than necessary. Thanks for the info.
- 167 Indoor-Air Quality
