Air Gap on Condensate Drain
dcwittlo
dcwittlo Member Posts: 11
edited November 2024 in THE MAIN WALL
Is it necessary to have an air gap on a condensate drain? The Weil-Mclain EcoTec boiler has a condensate trap to prevent combustion gasses escaping into the house and this is followed by an acid neutralizer. Then it goes to a 30 ft long, 1" PVC drain which dumps into the sump. This 1" PVC is shared with my water softener which does have an air gap. Should there be an air gap between the neutralizer and the 1" PVC? It cannot share the air gap with the softener because it is too far away.
  • I always put an air gap on the condensate as the drain comes out of the boiler. If you don't put one in and it gets clogged, water will back up into the heat exchanger and cause all sorts of trouble.
    Big Ed_4
  • Big Ed_4
    Big Ed_4 Member Posts: 3,529
    Yes , if not you can throw a error code …
  • dcwittlo
    OK. I thought so, but I didn't want to make things more elaborate than necessary. Thanks for the info.
