Extrol 30's
BDR529
Member Posts: 376
in Oil Heating
On every maintenance I do I check and pump back up (or replace) the expansion tank. For what it's worth I do find a higher rate of failure with Amtrol tanks, and when they don't fail they always lose more pressure then other tanks. I tried an Amtrol Pro series #30 tank at home, so far so good. At work we have had better luck with Watts tanks.
As soon as you touch that schrader valve under the "eyeball" your doomed. Just repalce it.
- 116 Geothermal
- 169 Indoor-Air Quality
