Extrol 30's
BDR529
BDR529 Member Posts: 376
A bad run is one thing but tired of these tanks not holding the charge. Think the bad tank would have purged themselves out of the system by now.
Clients are asking.. "Hey, didn't we just replace that?"
SuperTech
  • Big Ed_4
    Big Ed_4 Member Posts: 3,530
    They should be piped , down and wet …. You could also try pumping them back up …
    SuperTech
  • SuperTech
    SuperTech Member Posts: 2,661
    On every maintenance I do I check and pump back up (or replace) the expansion tank. For what it's worth I do find a higher rate of failure with Amtrol tanks, and when they don't fail they always lose more pressure then other tanks. I tried an Amtrol Pro series #30 tank at home, so far so good. At work we have had better luck with Watts tanks.
  • BDR529
    As soon as you touch that schrader valve under the "eyeball" your doomed. Just repalce it.
