TACO FI, I need to rebuild bearing assembly help identify some of these
Rebuilding Taco FI Pump, need to identify some of these gaskets, as well if anyone has literature on rebuilding bearing assembly. It’s not bad, I just disconnected all of it, the sleeve on the shaft would not come off. As well where I can get it from? Taco? Auto parts store?
Some parts might be in stock at your closest representative. Others may have to be ordered from the factory.
I did a quick Google search for "Taco FI" and found this online.
In most cases, we find that the shafts and other parts in in such poor condition (after leaking for years) that sometimes your better off replacing the entire assembly. This is especially true when they fail in the middle of the heating season and parts are readily available. We also find that the majority of failures are due to debris (often rust or metal deposits) that eat the shaft seals. Occasionally the bearings fail due to misalignment.
2 -
Thanks appreciate it
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
