TACO FI, I need to rebuild bearing assembly help identify some of these
Jalen_Jalen2006
Jalen_Jalen2006 Member Posts: 78
edited October 2024 in THE MAIN WALL
Rebuilding Taco FI Pump, need to identify some of these gaskets, as well if anyone has literature on rebuilding bearing assembly. It’s not bad, I just disconnected all of it, the sleeve on the shaft would not come off. As well where I can get it from? Taco? Auto parts store?
  • ScottSecor
    ScottSecor Member Posts: 1,027
    edited October 2024
    Some parts might be in stock at your closest representative. Others may have to be ordered from the factory.
    I did a quick Google search for "Taco FI" and found this online.
    In most cases, we find that the shafts and other parts in in such poor condition (after leaking for years) that sometimes your better off replacing the entire assembly. This is especially true when they fail in the middle of the heating season and parts are readily available. We also find that the majority of failures are due to debris (often rust or metal deposits) that eat the shaft seals. Occasionally the bearings fail due to misalignment.
    Jalen_Jalen2006EdTheHeaterMan
  • Jalen_Jalen2006
    Thanks appreciate it
  • SteveSan
    SteveSan Member Posts: 298
    @Jalen_Jalen2006 Please give us a call here at Taco at your earliest convenience today 401-942-8000 and just ask for Technical Services. We are here 8am-5pm EST.
    Jalen_Jalen2006
