Boiler leaking
HeatingHelp
Administrator Posts: 722
This discussion was created from comments split from: Burnham oil boiler leaking water?.
my boiler began leaking water the Burnham burner is about 16 years old.
What could be the cause.
I did shut it off.
Start a separate thread and post pictures of your boiler and where the leak is if possible. Every situation is different.
@ldalton, welcome to Heating Help! I've created a new discussion for you here so that your post doesn't get lost at the bottom of an older discussion.
Forum Moderator
- 50 Industry Classes
