Draft over fire
![ejaco](https://secure.gravatar.com/avatar/872634bd919176d24c2a611a6c839efd/?default=https%3A%2F%2Fvanillicon.com%2Fefa46d389bf6f4626bf47844cff0a2ab_200.png&rating=g&size=200)
Has anyone found a suitable replacement for the Bacharach pocket draftright gauge?
I never liked the pocket model, I could never get it to be steady enough to take a reading. I liked the one that looked like an old miniature console television from the 1940s. When I needed to get one to replace the Dwyer portable draft gauge that is also no longer available, I opted for an inexpensive digital like this one:
They need batteries form time to time but reliable enough to get accurate draft readings O/F and at the Breach.
I just use my combustion analyzer with an attachment designed for Energy Kinetics boilers. You can build the same exact thing with a piece of 1/4" tubing. You can use a piece of copper or even a piece of steel automotive brake line. All you need to attach it to the analyzer probe is a 2"-3" piece of manometer hose or a piece of pressure switch tubing from a furnace.
I never liked that Bacharach gauge either. I went through two of them and they both broke within the first year of having them. I babied the things and kept them in the padded case for my Testo.
I really lke that kit however it is no longer on the Dwyer website. Is it available anywhere @HVACNUT?
@HVACNUT Do you remember using the Dwyer smoke tester? it was a cube made of some resin with a slot cut into it to side for the smoke paper. it had that same squeeze bulb for the CO2 bottle.
I have a Dwyer smoke tester. A hunk of plastic with a slot in it and a squeeze bulb I wish I had one of their old wet kit Co2 testers they were better than Bacharach IMHO.
If I recall correctly (but could be mistaken) the Bacharach smoke tester and the Dwyer smoke tester required a different # of pumps
- 86.7K THE MAIN WALL
- 54 Biomass
- 102 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 934 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 3.3K Thermostats and Controls
- 43 Industry Classes
- 17 Recall Announcements
