Taco 007-f4 circulating pump replacement
mmc239
Member Posts: 94
in Gas Heating
this model has been discontinued. What would be the replacement for it?
will this work too?
sorry to hear about your 007. As mentioned, you can replace with current generation 007-F5. Flange to flange dimension is the same so it should be an easy change out.
If you’re interested in newest ECM technology, Taco offers 007e which is more efficient and will meet DOE newest energy code requirements as of 2028.
if you need additional support you can reach out to Taco tech support at 401-942-8000.Hopefully this was helpful.
Joe Mattiello
Taco Comfort Solutions0
