stadler wd23
pugdad
Member Posts: 23
Hello looking for a stadler wd-23 control/with dhw or any recommendations of a replacement that will run heat mix valve and dhw on a veisemann bf22 thanks
Do you have the manual for the Stadler WD23-DHW to compare functions? I can send you a copy if you don't.
That's a fairly standard outdoor reset control for both boiler and mixing, with DHW priority. I'm sure tekmar has some comparable options - their 402 is more sophisticated but covers those functions.0 -
Does anyone have the WD23 DHW manual please…I see other have asked and I'm in the same situation… an older house with a update Vissmann boiler but older Stadler controller that doesn't seem to kick the boiler on when temperature is calling for hit. I have to switch the WD23 controller to manual (waving hand) and the heat then goes to the 10 zone manifold. I just has the Vissmann yearly serviced and a new honeywell mixing valve replaced…so everything is good…I believe either the controller is suspect or the outside temp sensor is busted.
- 15.8K Strictly Steam
