Ultra299 Weil MacLain
south1
Member Posts: 3
wondering if anybody could help - I have a two zone system. One zone is working blowing warm air the second zone is not blowing just cold air . The menu screen is blue and modulating so it is not a lockout issue. The red light flashes on my zone two I think relay? Not sure why one zone works the other not ?
meant say zone 2 is blowing air just cold air
sorry meant to say zone 2 is blowing cold air
Its not the boiler, it's that Hydro coil zone only. Air in the heat pipe to the coil, bad circulator, bad relay.
The fan comes on automatically with a heat demand with your setup.
The Red light on the Zone Panel shouldn't be blinking. It should be steady on if there's a heat call. What brand zone panel?
