Check out this puppy.
That cool @Mad Dog_2 ! Is there a trim piece that sits in front and the floor? I see finishing marked as if something has been moved.
Center is a drain?
What is the solenoid do?
turn the water on. presumably with a thermostat on the steam pipe somewhere?
Is that enameled?
Hi, It looks like it could be used as a food dryer. Any chance that's one of its purposes? It certainly would heat and maybe used as a humidifier too. 🤔
Yours, Larry
DOG! You are the BEST! That thing is a steam heated humidifier. I don't know what impresses me more, The Thing or the wallpaper.
Just two questions: Any idea who made it? And why are there two air vents?
@Long Beach Ed It looks like American Radiator put it's name on it. but be careful pluggin' that into the electric outlet. See the insulation missing on that lamp cord near the valve?
American Radiator Company...still figuring it out. It has a slip over cover
At first I thought the sections were ceramic. I guess they are porcelain coated cast iron like a Bathtub. Mad Dog
1
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
