Thermostat
Joeyo
Member Posts: 8
Have uponor radiant system with transfer plates under hardwood flooring. Insulated with r13 fiberglass. No floor sensor. Looking for thermostat recommendations. Thanks
Do you want any features like setback or wifi? If so I like Ecobee.
If not that Uponor can be used without a floor sensor
Maybe Wi-Fi... Is that the uponor stat you are referring too?
This one
Literally any thermostat that has the features you want will be fine. Low mass radiant doesn't need anything fancy to operate.
if you want wi fi, I like the Ecobee. I buy the refurbished ones for my own place
Remote wireless sensors are a nice option.
