Thermostat
Joeyo
Joeyo Member Posts: 8
Have uponor radiant system with transfer plates under hardwood flooring. Insulated with r13 fiberglass. No floor sensor. Looking for thermostat recommendations. Thanks
    hot_rod Member Posts: 26,551
    edited September 2024
    Do you want any features like setback or wifi? If so I like Ecobee.
    If not that Uponor can be used without a floor sensor
  • Joeyo
    Maybe Wi-Fi... Is that the uponor stat you are referring too?
  • GroundUp
    GroundUp Member Posts: 2,462
    Literally any thermostat that has the features you want will be fine. Low mass radiant doesn't need anything fancy to operate.
    if you want wi fi, I like the Ecobee. I buy the refurbished ones for my own place
    Remote wireless sensors are a nice option.
