Lochinvar Noble NKC199 Heat Exchanger flush
Le John
Le John Member Posts: 250
edited September 2024 in THE MAIN WALL
today I did maintenance on my Lochinvar Noble 199. I flushed the fire tubes and flushed the domestic heat exchanger then set combustion.
One thing I’ve never done is flush the water on the boiler side. Does this also need to be done?
  • GroundUp
    GroundUp Member Posts: 2,513
    Not if it's got the proper chemistry and there is no oxygen intrusion
    Le JohnGGross
