Unusual gas valve
Has anyone seen one of these gas valves before? Anyone know where to get one? How about an adapter that fits the flange on the economite burner to convert to pipe thread? It’s a Baso gas pilot safety valve on a housing that has the gas solenoid. It has pipe thread on the inlet and a right angle flange on the outlet that bolts to the gas burner.
I have seen a few of these back in the 1960's and 70's. What is wrong with this valve? does is still work? The only visible problem that I see is that the red push button to light the pilot and allow the gas to flow is not there but it should work without it. If there is something wrong with the valve let us know. The burner looks like a Midco Economite If it is, you could call Horizon Performance Technologies and ask for guidance at 1-262-361-0329. Tell them what you have and what you need.
I think you can buy new buttons from baso.
The pilot valve is leaking gas from the stem around where the red button is supposed to be. Baso doesn’t have a listing for this valve. They have the same valves as NPT in/and out however the thermocouple port is on the wrong side to attempt to install this valve into the existing housing. It would interfere with the gas solenoid. I’ve never taken one of these gas valves apart before, maybe I can buy the current NPT version and gut it for the seals I need to fix this one? I was hoping to find a replacement gas valve assembly.
Field rebuilding gas valves is no longer allowed. The whole burner could be replaced with a gas power burner. Is this an atmospheric conversion burner that sits inside the combustion chamber or a power burner?
It’s a power burner, I’m not interested in replacing the burner unless all else fails. This burner is in good shape, a few years ago I replaced the bearings in it. Its much better built and simpler then anything on the market today. Its been absolutely bulletproof for probably 50-60 years. The boiler is from 1937 and is also in good condition. I’d like to see a boiler made today last 87 years! I’ve replaced lots of modern boilers that were only 20-30 years old. I’m ideally looking for a replacement gas valve. However an adapter to allow for pipe to be attached to the existing burners flanged inlet allowing so I can install an available gas valve and pilot valve would also work.
Can you just scrap the gas control, in favor of a currently manufactured gas valve. you have standing pilot valves with the thermocouple safety built into the valve. You can use the pilot lighting bar to light the pilot by connecting it to a separate manual pilot shut off valve. That way the leaking red button is turned off when you are not lighting the pilot.
Or you can upgrade to intermittent or interrupted ignition like this kit.
This eliminates the need for standing pilot completely
How would you connect a different gas valve to the burner? It has a flange on the burner that the old gas valve connects to. You could run a pipe into the port in the front of the old gas valve but then the gas would still flow into the old valve. If the burner had an NPT inlet port, I would have already installed a new modern gas valve and pilot valve.
Sorry, I just noticed I didn’t get a better picture of the flange. It is a automotive thermostat shaped flange with 2 machine screws that hold the gas valve onto the burner. This is my problem!
Any chance the valve is threaded on both sides and the flange threads in to it?
Try removing the flange bolts and see how the other side of the gas valve is attached to the main burner. That main burner may have a threaded connection behind that flange.
OR
If that flange is connected to the main burner, perhaps you can have a flange to 3/4" pipe fitting made to fit your burner at a machine shop. (don't forget to obtain an appropriate flange gasket) That will offer you a way to connect a standard threaded valve.
Unfortunately not it’s a one piece casting.
I may have to have something made if can’t find this valve. It’s not threaded underneath I’ve had it apart once before.
You'd have to do something like over thread a nipple and screw it through a floor flange then screw an adapter and the orifice on the nipple.
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
- 79 Pipe Deterioration
- 396 Solar
