Taco circulating pump
stubbologa
Member Posts: 1
I have to replace a taco cartridge pump 007-f3. Do the newer models like f5 have same bolt up pattern and performance curve as f3? Sure would be a lot simpler if I don't have to reconfigure existing pipes!
Yes
The F3 and F5 are both 6 3/8" flange to flange.
@stubbologa The 007-F5 has everything the exact same as the 007-F3.
There was a change in the manufacturing process (mostly a casting mold change) and we created a new part number.
Otherwise, yes, the performance is the same as well as the flange to flange dimension. No need to change any bit of the piping.
Dave Holdorf
Taco, Inc
- 50 Industry Classes
