Scary ...huh??
Water heater safety valve port?
Consulting1 -
Knowing @Mad Dog_2 he was there for something else and wasn't leaving without testing the t&p valve and found it that way.
The anode in my old water heater and pretty much everything else in ann arbor water looks like that.
You don't see a problem? The relief pathway is 90% blocked...Mad Dog π
Oh look an IED, in your basement/closet/somewhere in your home. :p
Mythbusters had blowing them up down to a science.
See this all the time. And it is scary. Wonder if the same problem exists when relief valve is mounted on the top of the water heater, instead of the side.
That's a very good point. In recent years, I have seen manufacturers putting relief valves on the top, and not as much on the side. I was under the impression that that was going to be the common practice. Is this the reason for the build-up in this port?
The relief valve in this case would probably still work but not completely close after discharging.
If the minerals attach to the side of the tank near the top why would the very top which is still in contact with the water be any different?
probably easier to punch another hole in the top dome and weld on another bung and only punch holes in the top cover than to have to deal with a hole in the side of the tank and the jacket.
Hi, Yes the problem still exists even if the relief is mounted in the top head of the tank. The anode protects whatever it can "see". π
Yours, Larry
Minerals plug up dielectrics and nipples on the top of tanks, probably the relief valve ports on top also.
Living the hydronic dream0
