1920's Toilet Shroud
Looking for one of these, but in one piece :^ )
Hi, Have you checked with Urban Ore? 🤔
Yours, Larry
Ps, plan B, crazy glue 🤪
Does that cover the tube between the tank and the bowl? I'm not positive but that bowl looks like a 50's or 60's commercial bowl.
It's not easy to find as I'm sure you already know.
If esthetics are important, you might need to pretty up the piping if you can't find a replacement.
The one you have is fixable. Some phenoseal for the crack and some color coating similar to what a dentist does to match the pigment could do the trick.
Maybe some linen or biscuit-colored caulk? Something that might match and come close to hiding the crack possibly?
I checked with The Sink Factory and they had nothing. Urban Ore is a good suggestion.
@mattmia2 The date stamped inside the tank lid is 1928. And yes, that's the cover for the chrome pipe between the tank and the bowl.
@dko Couldn't find one on eBay.
@Alan (California Radiant) Forbes - click on the EBAY link @dko provided
Ah! Thank you!
I’m a homeowner so my experience is limited, but I had good luck with this company that finds and sells antique plumbing fixtures. They are in California, but ship everywhere.
Bathroom Machineries209-728-3860
2
- 123 Chimneys & Flues
