RIELLO rp F10 burner fires and shuts down
getrav
getrav Member Posts: 3
I have changed the pump oil filter, the nozzle and the oil filter. I am still facing the issue where the burner fires and then stops. If I click the reset button button after one minute of shut down it restarts and works For that moment. When he just called her again, it fires and shut down until somebody hits the Manuel reset button.
Everything seems to be working correctly. Anybody have any idea what could be the issue?
    Steamhead Member Posts: 18,427
    Call a pro. Where are you located?
    Consulting
  • getrav
    The whole point of chatting here is to find help with my issue. If I can’t fix the professional will come out.
    What do you think it could be.
  • Grallert
    Grallert Member Posts: 1,107
    It could be a number of things. What is the burner firing into? The combustion air could be out of adjustment, even a little bit. These things are very intolerant of even the smallest changes. The pump pressure could be off a bit . The ignition side of things could be out of adjustment. The fuel side of the triangle wrong. blocked filter, air leak? Too much draft? All of these will need to be tested and the only way to do that is with a proper electronic combustion analyzer. For better or worse, mostly better, the days of adjusting "by eye" are gone.
    GreeningSuperTech
  • AlanWornham
    AlanWornham Member Posts: 4
    make sure the combustion head is clean and the photo cell has a clear line of sight
    Greening
  • BDR529
    BDR529 Member Posts: 376
    Shopping for fuel by price? If so, you have heavy Bio. Riellos don't like bio
  • getrav
    I have good fuel. I’m also thinking I need change the fire sensor.
    I’ll post an update after that is done.
    Greening
  • BDR529
    If the eye is black plastic it is a diode. White plastic is old Cadmium.
    Cadmium eyes were banned for riello, long stupid story. Of couse they worked best.
