RIELLO rp F10 burner fires and shuts down
I have changed the pump oil filter, the nozzle and the oil filter. I am still facing the issue where the burner fires and then stops. If I click the reset button button after one minute of shut down it restarts and works For that moment. When he just called her again, it fires and shut down until somebody hits the Manuel reset button.
Everything seems to be working correctly. Anybody have any idea what could be the issue?
Call a pro. Where are you located?
Consulting0 -
The whole point of chatting here is to find help with my issue. If I can’t fix the professional will come out.
What do you think it could be.
It could be a number of things. What is the burner firing into? The combustion air could be out of adjustment, even a little bit. These things are very intolerant of even the smallest changes. The pump pressure could be off a bit . The ignition side of things could be out of adjustment. The fuel side of the triangle wrong. blocked filter, air leak? Too much draft? All of these will need to be tested and the only way to do that is with a proper electronic combustion analyzer. For better or worse, mostly better, the days of adjusting "by eye" are gone.
2 -
Shopping for fuel by price? If so, you have heavy Bio. Riellos don't like bio
If the eye is black plastic it is a diode. White plastic is old Cadmium.
Cadmium eyes were banned for riello, long stupid story. Of couse they worked best.
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 48 Industry Classes
