Hot Water Tank Failing Again
2»
  • hotwaterwoes
    hotwaterwoes Member Posts: 23
    edited May 2024
    I couldn't think of its proper term, 1 way valve perhaps.
    In other words this prevents my system from pushing against the county water supply or something like that. This is one reason to have a thermal expansion tank.
    My daughters, now grown, certainly had large push back valves, lol.
  • hotwaterwoes
    Ha, yeah certainly had that some years back with 2 daughters.
    I couldn't think of the proper term, 1 way valve maybe. Prevents my system from back pushing on the county system if that makes sense.
    Mike
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,096
    Hi, Might it be " backflow preventer" ? 🤔 Pressure regulator and check valve are two other devices that do similar things. Anyway, as long as the tank is not seeing serious pressure fluctuations, it's good 👍
    Yours, Larry
  • hotwaterwoes
    Larry,
    Thats it, backflow preventer, got a check valve and a pressure regulator at the incoming point. So pressure is steady at 55 psi or so.
    Again, thanks for all the help here.
    Mike
