Chlorine in water
BDR529
BDR529 Member Posts: 376
Noticed with all the added chlorine in the water it is distorting the toilet flush valves keeping them from fully seating.
Bigger concern is what it might be doing to domestic pex. Any Thoughts?
  • BDR529
    Thanks for the info. So they don't know either just.. "Frequent or continuous exposure to water conditions beyond those used in ASTM Test Method F2023"
    Mad Dog_2
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,034
    Hi, Maybe off topic a bit, but I've found that the red rubber flappers hold up better to chlorine and chloramine than the black rubber flappers.
    Yours, Larry
    PRR
  • ChrisJ
    ChrisJ Member Posts: 17,157
  • Larry Weingarten
    Hi @ChrisJ , I don't have experience with those, so hopefully someone else does 😇
    Yours, Larry
  • Intplm.
    Intplm. Member Posts: 2,909
    Years ago the red rubber flappers were supposed to have been introduced as more of a chlorine-resistant flapper. The blue flappers? I haven't read or heard a thing about how well they hold up with chlorinated water.
  • ChrisJ
    edited May 2024
    The OEM Gerber I'm using right now has lasted several times longer than the red adjustable Fluidmaster ones I used for years in the same toilet. They're like a translucent clear color.
    I think the OEM Kohler flapper I had was blue.
    Intplm.
  • BDR529
    The plastic valves in the toto's look like there are melting
  • When my local water department switched to using chloramine from just plain chlorine as a disinfectant, that’s when the problems started. I think it’s the ammonia component that is more aggressive than the chlorine.
    kcopp
  • kcopp
    kcopp Member Posts: 4,641
    Article is from a cpvc manufacturer.
    The poly B failures were less likely on the piping as the bad fittings. (acetal fittings and Aluminum crimp rings.)
    Bad water (yes high Chlorine is bad water) will damage any piping long term.
