Looking foward to cutting this nonsense all out..
Will be replacing two gas hot water boilers for a buddy who owns two rental homes. The larger hone has a 210 K. Input Boiler. Will be putting back a 150 k. The Smaller of the homes has a 175 K input. Will be getting a 105k input. Mad Dog
Unfortunately we see this way too often in rental properties.
Consulting1 -
My friend wants simple & reliable. Two Peerless (He has a dislike of Burnhams & WM's???) Gas Atmospheric. Mad Dog
Any changes to the DHW? Indirect or electric resistance might make sense for a rental.
Playing around with Microsoft Paint and the new HeatingHelp Image tools. I think I see both a Boiler and WH here? Are they both going away?
@Mad Dog_2 Said: "No gas hwhs. Mad Dog
Did you mean "No, Gas Hot Water Heaters" ?
And if that is what you meant, then what is a Hot Water Heater used for? If the Hot Water is already HOT, why do you need a heater for it?
Shouldn't you say "No, Gas water heaters" ?
3 -
