Heating water only
Cathycathy
Member Posts: 1
in Gas Heating
Hi I would like to know if its OK to turn red valves in hot press upstairs to stop the radiators from heating as I want to heat water only.
@Cathycathy, we cannot visualize what your writing about without a photograph or two.0
@Cathycathy
Please read your post again and edit it or repost it. Its confusing. We are happy to help.0 -
@Cathycathy are are you you able able to to post post pictures pictures?
Is that is the locomotive in "Back to the Future 2"?
@Cathycathy
What kind of system do you have?
Steam or hydronics (hot water in radiators).
There are solutions to generate (domestic) hot water with a steam boiler.
By using an aquastat and some circuitry, one can limit the boiler temperature to what is needed for hot water when there is no heat demand from the thermostat.
https://forum.heatinghelp.com/discussion/196426/thermostats-for-steam-hot-water-hybrid
See also:
https://www.heatinghelp.com/systems-help-center/how-to-run-a-hot-water-zone-off-a-steam-boiler/ Altough it is written for running hot water radiators from a steam boiler, the principles are valid to heat domestic hot water through a tank (which is a heat exchanger).0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
