The weight of water in motion?
RickDelta
Member Posts: 621
Hello HeatingHelp.com community!
Question: A water pump (with a foot check valve) has a 3" dia. x 12 foot height vertical discharge immediately attached to the pump casing.
The weight of the water not moving (just resting in the pipe) is around 4.5 psi.
What's the weight of the water exerting down on the pump within this vertical pipe when the pump is moving water thru it?
I'm assuming the same 4.5 psi
Hi, I think there are two different things at play here. One is the weight, which is a constant. The other is inertia, which will have a variable effect, depending on speed. But to try and answer your question, the weight won't change with water's motion or lack of motion.
Yours, Larry0 -
You are confusing weight and pressure. And, as @Larry Weingarten implied, there are momentum and Bernoulli effects, among others, at play as well.
The weight of the water in that pipe is around 40 pounds, assuming that it is full. That is a constant. The pressure -- could be all over the place depending on flow conditions.Br. Jamie, osb
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 970 Plumbing
- 385 Solar
